31st January 2013, 07:23 PM
Help help help gu 3l just blew up
Hi, Im very desperate for advice, Ive just found out a new 3l motor I installed in the car has just broken its crank shaft and its only down 60,000km, Can anyone tell me where I legally stand I could really use some good advice . The NISSAN DEALER are trying to blow it of as being past the warranty.
Thanks can really use the help
Craig from SA
31st January 2013 07:23 PM
31st January 2013, 07:27 PM
Hardcore
What was your warrenty and what was the cause of you crank shaft failure I have not heard of this problem before
Such is the rule of honour.
The Following User Says Thank You to macca86 For This Useful Post:
craigv (31st January 2013)
31st January 2013, 07:28 PM
SUCH IS LIFE
So it was an old vehicle and you had a new motor put in by the Nissan dealer? or was it a purchased from the dealer with 60000 on it and blew.
What model vehicle?
Sorry to hear though mate
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
31st January 2013, 07:29 PM
Moderator
Yep need some time lines too mate. Was it a new crate engine? Why did it blow?
Check out my Toy -->
Rogue Dung Beetle
31st January 2013, 07:30 PM
Are you sure it's a broken crankshaft and not a broken flex plate?
31st January 2013, 08:00 PM
Well first thanks for everyone replying Ill try to explain in one go, 20,000 WARRANTY ON MOTOR and has been in for 2yrs. so far what happened was driving home the other night and felt a slight vibrating coming through the car on the freeway and thought I lost a weight of a rim, The next day I drove the car out of the yard and the vibrating got worse so I pulled over and checked under bonnet , got back in to turn around and head home and it started to really buck and stalled. Had it towed back to the nissan dealer and noticed some trans fluid on the tow truck tray and then thought maybe torque converter or flex plate let go, Nissan said it was probably the rig gear and after I showed them the fluid said the auto was probably gone and I should sell it as is. So I took it to a Trans shop for 2ND opinion the next day and was told they cant get the trans out because the engine is seized up and they can see the flexplate rocking from side to side when they try and turn it over buy hand thinking the crankshaft is gone.
31st January 2013, 08:05 PM
It is an old vehicle 2000 model and a brand new motor from the Nissan dealer installed. The thing hasnt towed anything , auto and I dont rev it over 3000rpm and serviced regularly.
Thanks for the interest.
31st January 2013, 08:08 PM
Moderator
Ah damn that sux big time mate! I am not sure you have any claim based on those time lines. Bloody bad luck though!!!!
Rogue Dung Beetle
31st January 2013, 08:14 PM
Trans shop is 99.9 percent sure its the crankshaft and. had the starter motor out, they said they have never not been able to turn a motor over before
31st January 2013, 08:31 PM
Hardcore
Sorry you're past your warranty I know someone from Brisbane with a zd30 for sale if you need a replacement. A rebuild would be the go bit expensive. Good luck hope someone can point you to a good mechanic your way
