4th February 2013, 09:56 PM
rd28 enthusiast
hi guys ive been searching but havent found what im looking for so to the rd28 ppl out there
is the gq rd28 flywheel solid or duel mass ? solid
will the gq flywheel fit the gu ? yes if the spacer is removed and a gq crossmember is used
is the clutch the same between gq/gu and soild/duel mass ? yes
what is the spacer for between the motor and box on a gu is it clearence for the duel mass flywheel ? clearance for the dual mass
will the gq rd28 gearbox fit the gu and are the bell housings interchangeable ? gq gearbox will fit if you run gq flywheel and gq crossmember and leave the gu spacer out
Reason: answering for others interested
The Following 3 Users Say Thank You to mud mut For This Useful Post:
NissanGQ4.2 (4th May 2013), nissannewby (3rd May 2013), YNOT (5th July 2013)
4th February 2013 09:56 PM
4th February 2013, 10:31 PM
I'd be giving Nissan newby a PM, He'll have all your answers
3rd May 2013, 11:29 PM
more info that is hard to find for the GU rd28eti
glow plugs part number: NGK Y701J
power steering belt part number: 13A0760
13A0775 is too long
The Following User Says Thank You to mud mut For This Useful Post:
4th May 2013, 04:32 AM
rb conversion hahaha !! =D
6th May 2013, 03:48 AM
ive always actually wondered why are the rd28s renowned for being the bad ones? i still see so many running and on the road?!
16th June 2013, 02:30 AM
one less on the road and sitting in our garage collecting dust, another TD42t on the road.
All I can say to answer your question burgo88 is only two words Harmonic Balancer.
5th July 2013, 12:12 AM
my harmonic balancer damaged the woodruff key and the key way in the crankshaft i just removed the damaged woodruff key got a new harmonic balancer / balancer bolt and washer and done it up to specs marked it and just keep an eye on it done 20000k as long as the timing gear keyway is good nothing bad can happen motor has done 350000k and still going strong
