Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: plas rope
    brisbane
    rope is a lot easier to work, once you try it you won’t go back to wire, the main reason i mentioned it jamming earlier is when most people upgrade to rope they more the likely upgrade its thickness and Length therefore maxing out the available space on the winch so for example if you are pulling slightly to the left and it keeps winding on itself and your unaware there’s a higher chance of it filling and jamming. The main thing that would kill your rope would be winching on rocks ledges and having it rub on the rocks so it’s just common sense treat it like you would any rope but keep in mind your pride any joy will be hanging on it lol.
    The big plus for me is that it is so much safer than a wire rope.
    If plasma breaks it basically falls to the ground with very little re coil you then tie a knot and continue.
    Wire rope will cut a limb clean off, must be some terrible injuries from days gone by, To avoid your plasma breaking over rocks
    pack a length of conveyor the width of your cargo area, lay it down over sharp rocky/terrain.
  4. #13
    plas rope
    No splinters either. Those things suck.
  5. #14
    330 Post(s)
    It is a great technique when spooling on your rope to not be too concerned about nice layered runs. I fact they are your enemy. Tight spools like a steel cable will jamb if you do a big heavy hard winch pull and the upper layers will jamb and embed into the power layers and can be a right biatch to get out.
    You should unspool at the top of the winch hill at least the amout of rope you just used and spool in properly.
    Spooling properly should be done like this.
    Winch in constantly. The winch man should allow the rope to spool on and every 15 seconds or so do a fast slash of the rope from one end of the drum to the other dissecting the spool. If that makes sense. You will do that 3 or 4 times back and forth then spool on straight again. Repeat.
    This then puts cross sections under the layers of rope and the layers can't embed in the layers below.
    Winner!
    Ben-e-boy (6th February 2013)
  7. #15
    If you have a low mount with the brake in the drum which is where most of them (but not all) are located...... Avoid winching out unless it is absolutely necessary. Definitely resist the urge to power out the cable and disconnect the drive using the clutch and run out your rope by hand.
    Winches with the brake in the drum disperse the heat generated by conduction thru the steel winch cable in contact with the drum and convection thru the air gaps in between the wraps.
    Synthetic packs virtually flat with no air gap and is a very poor conductor of heat. This traps any heat in the drum and can be a significant issue. On a couple of occasions I have had to strip down winches for people that looked like a plastic dinner plate had been wrapped around the drum and melted with the oxy but the outer wraps were fine
