Page 98 of 116 FirstFirst ... 488896979899100108 ... LastLast
Results 971 to 980 of 1157
Thread: Winnies 747 TD42 GQ
  1. #971
    Hmm. Could have been a possible gasket/head issue and has ingested some water causing a hydraulic situation.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (7th October 2018)
    194 Post(s)
    Matt, how much water would you need at say 2000rpm to give a hydraulic lock up? This would be more than a weeping leak wouldn't it?
  5. #973
    Not much. Probably not even a tablespoon. What can happen is you can have a blown gasket or cracked head, while running this may not be a problem. Its when the vehicle is stopped and it can leak some coolant into the bore. Then when you start it next time it can bend the rod. There are many other variables and consideratios to take into account. But not returning coolant and having a pressurised system (coolant being pushed out of expansion tank.) Can be a sign of conbustion pressure entering the cooling system.
  6. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (7th October 2018), PeeBee (7th October 2018)
  7. #974
    192 Post(s)
    Fark winnie, shattered mate that really sux, not what you really need at all. On the plus side pretty cool shed she's sitting in lol. Yell out if need a hand more than happy to swing a spanner or two, getting pretty down pat pulling these things in & out lol . .
  8. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    Avo (7th October 2018), Hodge (7th October 2018), PeeBee (7th October 2018), Winnie (7th October 2018)
  9. #975
    194 Post(s)
    Would you feel any vibration from a bent rod - assuming it can still cycle about the rotation? If its bent its going to sit in a different part of the cylinder as well I guess. I don't know much about this sort of stuff.
  10. #976
    43 Post(s)
    Yea fark Chris not a pleasant finish.
    Unfortunately I think that rad leak may have been a good contribution.
    As Matt mentioned it's not while running that's the issue..
    Hopefully that pump isn't impacted
    Bugger! Bugger! Bugger!
  12. #978
    Perth WA
    61 Post(s)
    Bugger mate......
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  13. #979
    I'm no expert but surely I would not have gotten 150km up the road if that were the case though?
  14. #980
    Yep. The bent rod can cause the bore to wear unevenly and the bottom rings to pull down further than usual and eventually fail.
