Page 95 of 116 FirstFirst ... 45859394959697105 ... LastLast
Results 941 to 950 of 1157
Thread: Winnies 747 TD42 GQ
  1. #941
    192 Post(s)
    Awesome Winnie looks smick mate, heck of a lot easier to brace out of the car mine was a nightmare and some of the welds look like bird cr@p but whatever. . . Reckon you should seriously think about powder coating them instead of paint, never get the chance again stripped and out of car. Mine looked nice and all painted but after a bit of driving through vegetation and what not look like poo again pretty quick. . .
    Hmm good idea... Any idea rough cost for powder coating? I've never had it done.
    Already spent a fair bit on it and still need to buy drag link and tie rod.
    Rossco (19th August 2018)
  5. #943
    192 Post(s)
    Couple of hundred should cover it maybe. Used a place in Moe before blast away sandblasting and he takes it to his mates for power coating, it's near the roundabout on the way out to Rawson. Will cost a bit extra but heaps worth it i reckon will look smick for years. . .
  6. #944
    194 Post(s)
    I had my SS snorkel done in Shepp and it cost $50. Bullbars were $150, reckon its probably a lot quicker than a bullbar, maybe the $100-125 at a guess. That included the light grit blast as well.
  8. #945
    Did you tack the housing to the bench or anything? Maybe check it for straightness before installing the components as the weld can pull it a fair bit.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (19th August 2018)
  10. #946
    No we didn't. My mate is a boily and was confident he would not bend it.
    How would you check it?
  11. #947
    192 Post(s)
    How'd he do the top brace, was it stiched bit by bit alternating sides or letting cool in between. ?
  12. #948
    Maybe some v blocks and measure at different points to see. I machined a length of 4140 rod up that passed through the front centre and into the other side. It was bent to start with and the shaft would not go through. A smll amount of bend is probably ok but if its to much you will destroy axle seals.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
  14. #949
    462 Post(s)
    I used POR15 on my rear diff and Aux tank. Bloody strong stuff.
  15. The Following User Says Thank You to mudski For This Useful Post:
    Hodge (20th August 2018)
  16. #950
    Got the rear diff out today, putting the new one in tomorrow and making a start on the front.
  17. The Following 6 Users Say Thank You to Winnie For This Useful Post:
    AB (9th September 2018), JackoGQYoot (9th September 2018), MB (8th September 2018), MudRunnerTD (8th September 2018), PeeBee (8th September 2018), Wine_maker (10th September 2018)
