Page 93 of 116 FirstFirst ... 43839192939495103 ... LastLast
Results 921 to 930 of 1157
Thread: Winnies 747 TD42 GQ
  1. #921
    192 Post(s)
    Yeah nice, be good to get the old girl back in the bush again , been a while. .
  2. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (28th November 2017)
    Finally got all the surfaces cleaned up properly, took all afternoon. Ready to start putting it back together tomorrow.
  5. The Following 4 Users Say Thank You to Winnie For This Useful Post:
    AB (2nd December 2017), mudnut (2nd December 2017), PeeBee (2nd December 2017), Rossco (2nd December 2017)
  6. #923
    Progress!
  7. The Following 8 Users Say Thank You to Winnie For This Useful Post:
    AB (11th January 2018), Avo (15th January 2018), Clunk (14th January 2018), GQtdauto (11th January 2018), MB (12th January 2018), MudRunnerTD (12th January 2018), Rossco (11th January 2018), Stropp (16th January 2018)
  8. #924
    Got the sump and balancer back on today and timing cover all torqued up. Should have the motor all back together tomorrow but don't have enough oil or coolant to run it.
  9. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (13th January 2018), Rossco (13th January 2018)
  10. #925
    New damper on it?
  11. #926
    New damper on it?
    No I used the old one.
  12. #927
    Nearly there....
  13. The Following 6 Users Say Thank You to Winnie For This Useful Post:
    AB (14th January 2018), Clunk (14th January 2018), MudRunnerTD (14th January 2018), PeeBee (14th January 2018), Rossco (14th January 2018), Stropp (16th January 2018)
  14. #928
    Got it running tonight and there are no leaks so far.
    I am having an issue with vacuum though which was present before I started this job. I have no vacuum assistance in the brakes or clutch.
    There is vacuum to both though but I'm not sure if it's enough? I wouldn't imagine both boosters going faulty at the exact same time.
  15. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (16th January 2018), Bacho86 (16th January 2018)
  16. #929
    Think I found my vacuum problem. It's a strange one though. If I block the hose going to the clutch booster then I have brakes working again. If I block the hose going to the brake booster I still have no clutch.
    The 1 way valve on the brake line works as It should.
    I pulled the clutch booster off and this is what I found.
  17. The Following User Says Thank You to Winnie For This Useful Post:
  18. #930
    Patrol God Stropp's Avatar
    31 Post(s)
    Bummer mate, more money but it will be worth it.
