1st February 2013, 08:12 PM
oil change
hi there
can someone tell me if i should warm the two diffs,gearbox,transfer before i change the oil
thank you
team grandpa
1st February 2013 08:12 PM
1st February 2013, 08:15 PM
I dont do it as all the metal is settled on the bottom
1st February 2013, 08:16 PM
Dont bother, just go and make a coffee and chill out while it drains!!!!
It can help to jack up sides of the car to get the oil out..
2nd February 2013, 06:10 PM
The oil will drain quicker if its warm, but id just drop the plugs while its cold and let it drain no hurry
2nd February 2013, 06:22 PM
X 3 with all above but get yourself a magnetic sump plug or place a magnet on you oil filter for next time M2cW
2nd February 2013, 07:20 PM
Patrol Freak
Always a good idea to warm it up. There is always crud floating around in the oil, although on a microscopic scale that will settle to the bottom on the sump that doesn't always drain out when the plug is pulled out. Running the engine/gearbox helps to suspend the crud in the oil and drain it efficiently.
