Results 1 to 7 of 7
Thread: 4.2 TDi - Turbo gaskets/studs
    WA Wheatbelt
    23 Post(s)
    I feel like a real newby asking a DAQ, coz I'm right out of my depth here.
    Well, here we go....
    I got my mechanic to change all the turbo gaskets on my 4.2 TDi and he said the better option would be to put studs in, too.
    What are studs, where do they go, and how do they help? Pics would help, too.
    The mechanic knows what he's talking about, I just need somebody to explain the process, please.
    Thanks in advance.
    Rossco
    Re: 4.2 TDi - Turbo gaskets/studs
    Take a look in the mirror mate, there's a stud right there, you studly studmeister you
    Don't stroke it, TAP it!!!!.....
  4. The Following User Says Thank You to Clunk For This Useful Post:
    DX grunt (29th January 2013)
  5. #3
    Here you go mate, pay close attention to the lat type
    http://en.m.wikipedia.org/wiki/Stud
  6. The Following User Says Thank You to Clunk For This Useful Post:
  7. #4
    Ballarat, Vic
    174 Post(s)
    Studs are the threaded bits that stick up out of the motor & pass through holes in the gasket & in the cover. A nut screws on to them to hold the cover on. They are threaded on both ends so they can screw into the motor. Usually inserted into the motor by spinning two nuts onto the stud & locking them together so the stud can be screwed in with a spanner. Usually loctited in. Good idea to replace them if blown gasket has been a problem. Reason is that the the nut is usually torqued onto the stud. When this has been done a few times, sometimes the stud stretches slightly & can result in uneven tightening when a new gasket is fitted.... gasket then blows again. Your mechanic may be being over cautious but in my view he's being smart. Cheaper to put in new studs whilst the cover is off & know the job is done right, rather than risk the extra expense of having to do the job a second time.
    Cuppa
    A Nomadic Life (Blog)
  8. The Following User Says Thank You to Cuppa For This Useful Post:
  9. #5
    WA Wheatbelt
    23 Post(s)
    Thanks Cuppa.
    Really appreciate your knowledge.
    I'd rather be over cautious than have to do it again. He's the local vehicle examiner as well.
    I'm gunna be a good customer of his. lol
    Take care out there.
    Rossco
  10. #6
    Advanced
    Jan 2013
    Most of the times we change the studs at work. Its not that much more to the cost of the job. Why did you change the gaskets? was there a leak?
  11. #7
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by TurboOne View Post
    I took it to a major franchise for a regular service and they told me the exhaust manifold gasket and a couple of turbo gaskets need changing - because there was a leak. I decided to change all the gaskets in the one hit, instead of only a couple. I don't have any mechanical knowledge, so I said do the lot in the one hit.
    I got all the gaskets through Nizzbits and I got my local mechanic to change everything. It sounds like a real truck - now. lol
    Rossco
