24th January 2013, 08:58 AM
Fitting water temp gauge to ZD30
Any one have a suggestion where to fit the water temp sender unit for a temp gauge, thnaks
Burto
24th January 2013 08:58 AM
24th January 2013, 09:40 AM
Some just tuck it back under the top hose, others with copper radiators silver solder a nut to top tank.
Not sure on the ZD30 where the best spot is to take temp, side of block etc,etc, Newby would have a better idea
Burto (24th January 2013)
24th January 2013, 03:07 PM
As close the the thermostat as possible. To as TD said in the top hose at the radiator, or on the engine side of the radiator.
26th January 2013, 04:46 PM
Thanks to you both, have decided to drill and tap the thermostat housing cover and fit the sender there.
26th January 2013, 05:16 PM
Use grease where you're drilling it will catch the filings, or are you removing housing from motor?
30th March 2015, 03:01 PM
How did you go with the drilling and tapping, need to do this myself shortely ?
Anyone know the size of the top radiator hose so I can buy one of those inline fitting if need be?
