Results 1 to 9 of 9
Thread: Second battery height issue?
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Hi guys. I am part way threw installing my second battery to the passengers side of the vehicle and I have a small issue.
    I've made my own bracket and its sitting within mm's of the wheel arch but the battery when in the cradle is sitting 10-15mm higher than the original.
    Is this a common thing with bought cradles aswell or am I missing something?
    If not could I bother you guys for a pic of were its mounted?
    Here is mine in the td 4.2
    Owner of
    Westy's Accessories
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    Hey Kal - is it causing an issue or are you just trying to get them flush? Looks good to me?
    Jas
    __________________________________________
    Roads? Where we're going we don't need roads.......
    2012 Silver GU 8. Bullbar, Warn XD9000 winch, snorkel, towbar, roof bars and rack, awning, 33" Mickey Thompson ATZ 4ribs, 2" lift - Dobinsons coils and Koni shocks, more to come......
    2013 Travelling Wilbury's Cape York Trip - bring it on!
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Re: Second battery height issue?
    It's not hitting the bonnet, but will be touching the insulation.
    Probably not a huge issue, I'm just wondering if the arb etc mounts are lower, and if so how??
    Owner of
    Westy's Accessories
    Legendary my third 256's Avatar
    Aug 2010
    adelaide
    tray is clooser to the motor and with the curve of the wheel arch will drop it a bit more (further out from overflow bottle)
    2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
    OH LEATHER IS NICE
  6. #5
    See you use a wet cell battery ,Best IMO messy but better, anyway if $$$$'s are there and you like them seach for side post style like the optima yellow or Blue.
    you can then use that battery for camp duties in a battery box, but the short answer is Mythird is right, bit more &arting around but....................?????
    Use penny washers /mudguard washers or it'll tear a huge hole out of inner guard
  7. #6
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Yea wet cell all the way. They take the most beating and bounce back..
    I've put my base on thin rubber blocks with mud guard washers either side of wheel arch.
    How close to the motor do the commercial holders sit? I don't want it to close to the exhaust or I'll fry it...
    Owner of
    Westy's Accessories
    W.A. (wandering aust)
    If the terminals are touching the heat insulation I would be worried the battery is too high and may short out due to bonnet flex etc if you hit the gnarly stuff.
    One of the guys in my Club had that exact issue.
    You might also get leakage thru the heat insulation if it gets wet.
    I'd be thinking of;
    mod'ding the tray,
    using a lower profile battery albeit you may have to scarifice some capacity, or
    putting an electricaly insulated barrier over the terminals and keeping an eye on how much if any the flex affects the clearance
  9. #8
    Is it possible to use the STD battery position to mirror off.
    Like would a LH version fit the RHS, you know what I mean
  10. #9
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Hi TD, yea I'm only 5mm off the original spot.
    I guess ill try lower the mount so its near on touching the guard.
    And I will be using terminal covers, even on the original battery
    Owner of
    Westy's Accessories
