Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Installing Pertronix ignitor II Distributor shaft machining
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Re: Installing Pertronix ignitor II Distributor shaft machining
    Good stuff pacs, you'll see a big difference in economy
    FanTapstic!
    Hello from Under Down Under!
    sunshine coast
    Does anyone have a picture of the mod to the shaft needed for pertronix ignition 2 before and after the grind I haven't pulled my distributer apart yet cause the car is my daily work horse and I can't afford to stuff up so if someone is able to post a pic it would be great thanks
  4. #13
    Apr 2011
    Melton
    I ground my dizzy today. I pulled the dizzy apart, and found I could pull the shaft off. I just span the shaft and ground it done using my bench grinder. (took about 30 seconds)
    The bit you need to ground is the stopped for the rotar button. I had to take a mm of the supplied spacer as I could not do up the screw that retains the rotar button.
    I went out to the melb supplier of the pertonix,as m,t ls version had a suspect fault - they refunded the money and I brought the magnetic sensor and a flame thower. THEY ARE GREAT TO DEAL WITH
  5. #14
    sunshine coast
    Does anyone know what the two blue wires are that are attached to the coil through one ring terminal
  6. #15
    Apr 2011
    Melton
    What terminal are they going to.
  7. #16
    Jun 2018
    Heyy man im having problems with mine it wont start did yours do this?
