Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: DP Chip fitting instructions
    461 Post(s)
    Quote Originally Posted by rotor138 View Post
    Legend! Now to go fit it!!
    Sent from my GT-I9100 using Tapatalk 2
    Erm, mines fitted... Just to add the two wires that go to the injector pump. On mine they were encased in the split tubing. I just used some 4mm twin core wire instead to run through the fire wall. So I didn't have to worry about making the hole any bigger. Good luck on getting the signal wire onto the pump. I said many a chosen word and came out with black and scratched up hands doing it as the wire off the pump is really short. If I have time I want to actually solder on the wire as I don't trust those dodgy wire clip thingo's supplied.
    Sep 2011
    The lack of support for their product in not providing simple fitting instructions without the reported fee means I will avoid them like the plague.
  4. #13
    461 Post(s)
    Quote Originally Posted by Jock View Post
    No reason to avoid them I think. If you buy a second hand product you got to expect little hiccups like this. A little asking and/ or Googling does wonders. Their product is good. Overpriced like all other chips. But good. There is some mob claiming, indirectly mind you, their chip will stop the Di's from grenading. I laughed when I read this.
  5. #14
    Advanced rotor138's Avatar
    So is mine now, can really notice it down low. Still not as good up hills as I thought it would be but happy the big flat spot is gone. Thanks again for posting up the instructions it really is much appreciated.
  6. #15
    461 Post(s)
    No probs. Mines good all through the rev range. I really notice it when I'm towing though.
  7. #16
    May 2020
    Gday all so where can I get the instructions for a dp chip 2006 DI .. ??
