10th January 2013, 01:39 AM
#11
$1000...
Again Jas, make a weekend of it and ill fit the lot...
Owner of
Westy's Accessories
10th January 2013 01:39 AM
10th January 2013, 04:56 PM
#12
Hardcore
Can you get the OME kit anywhere else other than ARB and what should it cost if you fit it yourself?
Jack
10th January 2013, 05:21 PM
#13
Moderator
OME is ARB. You will save $300 to $400 fitting the kit yourself. 4 to 6 hours if you have never done it before
Check out my Toy -->
Rogue Dung Beetle
10th January 2013, 06:39 PM
#14
Patrol Guru
MyTrol
Thanks Morton, i have decided on 2". do you have the tough dog foam cell shocks? if so how do you find them?
Mate I just ordered new shocks for my GU, all TD but have ordered foam cell for the front only to try them out, if they fail I will toss them to a mate & try something different, I have ordered adjustable for the rear as the rear weight changes all the time, I am always too heavy &/or too harsh on them, sometimes I am 0-200kg on the rear, sometimes 2-300kg plus camper depending where I am going & who & what I am taking, I think I need to seriously look at airbags, I am also thinking of getting rid of my steel bullbar & busted winch in favour of a stock alloy bar again, I am still in the whole process of resetting up my GU so I am playing around with all sorts of things to see what works for me & what doesnt, I want to try the foam cell on the front with & without the weight of bar & winch
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
10th January 2013, 06:56 PM
#15
Morton, is there really that much difference in weight between steel and alloy??? To it would have to be greater than 40-50kg to warrant changing.
10th January 2013, 10:26 PM
#16
Koni are great, pricey and rebuildable, Speak to your suspension guy as to what you want to fit like batteries ,winches, bullbars etc and he should tailor a system to suit your needs. Flexy coils are great too
23rd February 2013, 12:51 AM
#17
Patrol Guru
I ended up fitting foamcell on all corners & couldnt be happier so far, off road they are fine & they are built for touring so all should be good
