Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Recommended Lift Kit For My Y61 gu Patrol
    43 Post(s)
    $1000...
    Again Jas, make a weekend of it and ill fit the lot...
    Owner of
    Westy's Accessories
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Can you get the OME kit anywhere else other than ARB and what should it cost if you fit it yourself?
    Jack
  4. #13
    OME is ARB. You will save $300 to $400 fitting the kit yourself. 4 to 6 hours if you have never done it before
  5. #14
    Patrol Guru Morton's Avatar
    Sydney West
    Quote Originally Posted by MyTrol View Post
    Thanks Morton, i have decided on 2". do you have the tough dog foam cell shocks? if so how do you find them?
    Mate I just ordered new shocks for my GU, all TD but have ordered foam cell for the front only to try them out, if they fail I will toss them to a mate & try something different, I have ordered adjustable for the rear as the rear weight changes all the time, I am always too heavy &/or too harsh on them, sometimes I am 0-200kg on the rear, sometimes 2-300kg plus camper depending where I am going & who & what I am taking, I think I need to seriously look at airbags, I am also thinking of getting rid of my steel bullbar & busted winch in favour of a stock alloy bar again, I am still in the whole process of resetting up my GU so I am playing around with all sorts of things to see what works for me & what doesnt, I want to try the foam cell on the front with & without the weight of bar & winch
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  6. #15
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    Morton, is there really that much difference in weight between steel and alloy??? To it would have to be greater than 40-50kg to warrant changing.
  7. #16
    Koni are great, pricey and rebuildable, Speak to your suspension guy as to what you want to fit like batteries ,winches, bullbars etc and he should tailor a system to suit your needs. Flexy coils are great too
  8. #17
    Sydney West
    I ended up fitting foamcell on all corners & couldnt be happier so far, off road they are fine & they are built for touring so all should be good
