9th January 2013, 05:31 PM
Yeah ask Boots about that... his nice shiny GU has got some damage from exactly that and he was pretty pissed about it!!!!
9th January 2013 05:31 PM
9th January 2013, 10:10 PM
Nice job mate. I'd plate it as it makes sliding easier..
1mm check on top and 1.6 under will ensure a good life..
Owner of
Westy's Accessories
Yeh I used 50m ITD aswell, I'm still unsure which method I'll use to mount them yet.
9th January 2013, 10:18 PM
Well unless you wanna risk defects the clap style is your only real option.
Any welding or drilling of the chassis needs engineers certification.
Owner of
Westy's Accessories
9th January 2013, 10:39 PM
Westy's Accessories
Owner of
Westy's Accessories
Can you just clamp without drilling through the chassis wiithout a body lift?
9th January 2013, 11:47 PM
Yes, a u shaped bracket with bolt over the top of the chassis, but it requires a little panel beating up front to clear.
Are you intending in using the sliders, or are the a step / looks? If just for looks 2 brackets would be enough..
Owner of
Westy's Accessories
10th January 2013, 06:29 PM
#17
yeh I used three mounting points on mine with two clamp style ones, with two bolts in each and I don't have a body lift and the other one I made a bracket up which bolts up using the same points as the gearbox crossmember.
GQ Snorkle Lockers front n rear
19th January 2013, 11:34 PM
#18
haven't done much to them lately been finishing the rabbit hutch off, what are your thoughts on paint for them AND scrub bars once they are done, black or red to suit?
7th April 2013, 09:02 AM
#19
They look good so far,
I'm making a set for my gu now and have used 3 mounts.
Definitely black
