Results 11 to 20 of 28
Thread: tyre pressure
    Dec 2012
    I run 35. Any higher and I find the 80k wobble gets worse
    43 Post(s)
    40 here. Use to run 35 but the fronts scallop out to quick..
    Owner of
    Westy's Accessories
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Bloodyaussie (11th January 2013)
  5. #13
    Thomastown, Melbourne
    6 Post(s)
    Running such low pressures are so the ride seems smooth but what happens is the tyres wear too quickly and they generate more heat shorting there life.
    My little 2lt car can run 32psi but a 3t rig should run much higher
    I tow a lot so 42 psi for me but if I did not then 40psi would do but 35 psi and below is ridiculous...........
    Love to hear the reasoning others have for running low pressures???
  6. #14
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    Hi BA - agree - I run them at 38-40 cold. 42 laden. Only time I run them low is mud, sand, traction reasons.
    Jas
    __________________________________________
    Roads? Where we're going we don't need roads.......
    2012 Silver GU 8. Bullbar, Warn XD9000 winch, snorkel, towbar, roof bars and rack, awning, 33" Mickey Thompson ATZ 4ribs, 2" lift - Dobinsons coils and Koni shocks, more to come......
    2013 Travelling Wilbury's Cape York Trip - bring it on!
  7. The Following User Says Thank You to lorrieandjas For This Useful Post:
  8. #15
    WOW you guys run high pressures, I'll run 40psi for hwy duties and 35 psi around town, and down to 16 psi off road
  9. #16
    Brisbane
    Hi threedogs. I just based mine on what the dealer recommended - when I put the Mickey Thompsons on he recommended no lower than 38 on the black top - for all other surfaces was play it by ear. Also recommended 2-4 PSI increase for loads.
    Jas
  10. #17
    North brissy
    Google the 4psi rule for tyres. It basically explains that if you get a larger increase in pressure of 4psi after driving for a period then your pressures are to low etc etc. Its a little bit consuming to start with but once you have it sussed its all good. I dont run anything under 38psi.
  11. #18
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    You Guys definately run higher than me
    200(29) Front and 250(36) Rear
    No abnormal wear and a Good ride
  12. #19
    Brisbane
    Interestingly the tyre pressure placard on the 2012 GU 8 recommends 28 front and rear (30 if loaded on rear).
    Jas
  13. #20
    6 Post(s)
    Go by tyre manufacture not car manufacture.. they want it to seem comfortable... 29psi is just way to low for a 3t car... also what gauge do you lot use.
    Most petrol station gauges are out by a fair bit, I have an expensive gauge I got for racing and if using a petrol station I always check it and find some gauges can be out by as much as 10psi .
    My tyre inflator gauge is out by 5psi and it cost $60.
