15th March 2013, 01:41 PM
#21
Home Built Cargo Barrier
That is bloody brilliant Alex, great job mate, you should be proud of your efforts and idea mate, Absolutely love it. Good work,
TAPPN OUT
The Following User Says Thank You to wildgu6 For This Useful Post:
15th March 2013 01:41 PM
6th May 2013, 12:19 AM
#22
The Following User Says Thank You to leadsled For This Useful Post:
6th May 2013, 08:17 AM
#23
Daily Lurker
altech
very clever mate, does it rattle on the road at all?
12th May 2013, 03:20 PM
#24
rusty_nail
No ,not at all as you can by the video that I made up a spacer made from 3mm scarp wood and left over carpet and glued it on both sides , so it fits frame and perpex no rattle . and the perpex only go's up when needed . eg camping .. regards Alex
http://www.youtube.com/watch?v=TceKoWcsjY4
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
The Following User Says Thank You to altech For This Useful Post:
16th June 2013, 03:45 AM
#25
Mate the steel you found is called unistrut, it's the mechano set og building material. The railing supports hundreds of different types of clips for everything, I love the stuff.
Have look in this direction ,
https://www.google.com.au/search?q=unistrut&client=firefox-a&hs=bVv&rls=org.mozilla:en-USfficial&source=lnms&tbm=isch&sa=X&ei=qqC8UYDjDIbRk gX2yoG4CQ&ved=0CAkQ_AUoAQ&biw=1920&bih=976
The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
18th June 2013, 06:30 PM
#26
Cheers Mate that's the stuff and the steel was free , left over from work site.......... lol
18th June 2013, 06:37 PM
#27
The 747
sil3nt_dr3ams
Yeah unistrut is awesome stuff, I've made a few things out of it before, we have it at work
If you're happy and you know it tap a post!
The Following User Says Thank You to Winnie For This Useful Post:
26th June 2013, 12:45 AM
#28
The Following User Says Thank You to soronation For This Useful Post:
