24th November 2010, 11:45 PM
Wobbly fan
Im guessing the fan is not supposed to wobble on the shaft. it feels fairly firm to spin but you can wobble it around on the shaft. is it something that is repairable or any suggestions?
24th November 2010 11:45 PM
25th November 2010, 02:29 AM
Hardcore
New water pump mate, the bearing is flogged i'd say.
25th November 2010, 12:35 PM
GU 2.8
Depends on where the movement is coming from to what you will need to replace?
Is it moving just in the fan or when your moving it is the water pump pulley moving with it?
If the fan is the only thing thats moving then i'd say your viscus hub is warn out but if the pulley is moving as well I'd say your water pump is the culprit.
25th November 2010, 01:19 PM
Yes it's just the hub of the fan moving on the shaft. Is the fan rebuildable or do I need to replace it ?
25th November 2010, 05:54 PM
Replace the hub. Have a close look at the centre of the fan blades looking for cracks in the plastic. If you find cracks replace the fan as well.
Tony
26th November 2010, 07:26 AM
thanks for the help guys, i will chase up a hub today. They are about $230 new if anyone is curious.
26th November 2010, 11:27 AM
GU 2.8
The new fan is about $150 odd as well.
Try this bloke out before you hit Nissan: http://www.nissanpatrol.com.au/forum...-Nizzbits-(vic)
30th November 2010, 12:35 PM
#8
Got a fan on a hub from the wreckers for $77 with 3 months warranty
