I have managed to find a few different manuals on the net for the wiring diagrams but can't seem to find the info I need. I can't download the one on this site as I still dont have enough posts so thought someone might be able to answer instead.
I am putting a TB42 motor in it. Its what I got with the car and all I can afford to do at present.
From what I can tell by the wiring. The coil and dizzy are all on the drivers side in the RB patrol? Is that correct? Seems like i need to extent some of the wiring across to the passenger side for the normal TB setup.
Can someone also post a picture or something of how the coil and resistor mount. I can;'t seem to figure this out.
I'm sure I have more questions coming just want to sort 1 at a time lol.
I have found the white wire with black stripe that goes to the ballast resistor but I can't seem to find the red one yet that goes to the coil.
I have all the manuals I can find including the factory one off here. Also have a different one and I am borrowing a mates tomorrow think its a Mallory one with rb and tb in it.
Last resort I will use a relay to split the signal from the starter motor solinoid. Thats all it is 12v to the coil while key is in the start position.
Think I have most the other stuff sorted.
You might be able to answer this. Did the RB30 have auto choke and fuel cut solinoid like on the drawing you took a snap shot of?
I am pretty much in it. Surrounded by it and about 100mtrs drive to actually get in bush. Is awesome.
I will have another look throuhg loom. The wire might be there just cut back. The car had a chev in it before i bought it so who knows what last person done with it.
