Hi Guys, got some cheap led lights of ebay which I used on my draw unit that I built 6 months ago and posted , as you can see by the pic's there work quite good and to make them come on I just ran I wire from the door light at the rear, No fancy mirco swiches here. It's like this you have to open your barn doors first to open your draws and leds run on min amps too , thanks Alex
Hi guys, just some pic's at night time as you can see work well regards Alex
That's a great a simple idea for anyone to do at home. Well done, simple thinking.
Looks really nice set up. Even I am searching for such cheap lights which are bright enough in store rooms..You have given me real good option
