Results 1 to 7 of 7
Thread: How to use the space?
    Jul 2012
    Anglesea Vic
    Hi all
    I was wondering what you have used the space in the engine bay for? We go bush camping a bit and I was thinking along the lines of either a water heater or air compressor. We have batteries in the trailer and a solar set up so dont think I need to put an extra battery in there.
    We drive a 2008 ST 3000ltr GU. Any thoughts or suggestions gratefully received
    Richard
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Usually you'd figure out what you really want or need to have and then try fit it onto your patrol. But yeah, a heat exchange hot water system or a compressor are common things to have under the bonnet.
    Hello from Under Down Under!
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by richardl View Post
    Hi all
    Richard
    Ritchie, if you really want to utilise all that space in a 3lt engine bay, would be to put in 6.6lt twin turbo Diesel engine. Surely that would fill it in.
    ImageUploadedByTapatalk1356645205.778573.jpgImageUploadedByTapatalk1356645217.957674.jpg
  5. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    DX grunt (28th December 2012)
    WA Wheatbelt
    23 Post(s)
    Definitely HWS.
    Rossco
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Hot water would be nice...
    Compressors are better mounted inside the cabin.
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
    Brisbane South West
    I agree with BearGUST, hot water under the bonnet. ARB air compressor fits nicely under the passenger seat and is able to get cool air from the a/c with the outlet nearby. No need to drill any holes mounted using three bolts with the ARB bracket.
  9. The Following User Says Thank You to daggy For This Useful Post:
    richardl (28th December 2012)
  10. #7
    Patrol Guru Morton's Avatar
    Sydney West
    I fitted my ARB compressor under the bonnet of mine in the rear corner on the passengers side, no good though if you have ABS as this will take up the area, other wise under the drivers seat as mentioned earlier, I run both ways, my GU had the room under the bonnet, dont know the life expectancy of it though as it gets hot under there, the Maverick was already mounted under the drivers seat
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
