27th December 2012, 06:53 PM
Overheating
Hi all, have an issue with a TD42 overheating. It had pretty grotty sludgy coolant so flushed system and changed coolant. It wasn't overheating prior to flushing and changing coolant. Have pulled thermostat and checked - OK, then left it out, flushed both ways, pulled water pump - impeller OK. Starting to think sludge may have blocked a heap of cores. The radiator cores externally are good. No bubbles in radiator indicating head gasket or cracked head. Anyone had this type of experience? Know of any method of cleaning the cores maybe with acid or will this kill the radiator? Thanks for any help, Bill
27th December 2012 06:53 PM
27th December 2012, 08:52 PM
BIG & BALD
You may want to do some searches for overheating, there is a heap of info.
All with a common problem of blocked radiator core, when using different types of coolant. Take it to a radiator joint and get it checked thoroughly. Cos if thus forum is anything to go by it'll be a blocked radiator.
27th December 2012, 08:59 PM
Thanks Mego, sounds like that is the way to go, cheers, Bill
I am he, fear me
X 2 with MM... Get the radiator core rodded out.
27th December 2012, 09:08 PM
SUCH IS LIFE
x 3 Heard too many bad stories even with brand new radiators being blocked
________________________
______ 2017 D-Max _______
27th December 2012, 09:15 PM
Patrol Freak
All you did was empty it and then fill it again. Could it be an air pocket? Are your hoses OK - or are they soft? Look at obvious stuff first. What happened between when it was OK and now?
28th December 2012, 08:29 AM
Radiator rodded,only way to clean properly
Cost ohh,about $100 ,and you remove and refit, could be cheaper could be more
Throw new top bottom hoses on same time, new thermostat,full block flush as well,while your at
Should be sweet then
28th December 2012, 09:57 AM
X 2 with MQ MAD get the radiator rodded, different coolants react and form a gel use only OE thermostat and fit new hoses. last thing you want with summer upon u is overheating problems
28th December 2012, 05:55 PM
BIG & BALD
Someone put Goats nightmare link for this mug. anic
28th December 2012, 07:34 PM
Patrol Guru
2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
