29th December 2012, 07:22 PM
#21
Legendary
Thanks guys i'll give it a crack and thanks alot for all your help
29th December 2012 07:22 PM
29th December 2012, 08:57 PM
#22
Rotaredom
I have been over and over the GU manual in the AT and EC Section for the TB45E and still can't for the life of me find reference to code 21 being turbine sensor.
Correct me if I'm wrong guys but this is what I get "IGN SIGNAL-PRIMARY" (DTC 21)
29th December 2012, 09:45 PM
#23
Legendary
NissanGQ4.2
Thats more then what i found, but if that is in the engine ECU i get 55. System normal when i check it.
Tomorrow i will do a manual test and count the pulses of the power button, and i might manually go thru all the sensors with an ohm meter and volt meter and check resistance's and voltages of every component that has to do with accelerating, shifting and cruising circuit, i'm gona have fun!!
29th December 2012, 09:46 PM
#24
I couldn't find it either.
I think if he flashes out the code it will just come up as the revolution sensor.
31st December 2012, 11:10 AM
#25
Rotaredom
31st December 2012, 05:43 PM
#26
Legendary
Not yet sorry been busy organizing NYE party, but my new years resolution is to fix my fault !!
2nd January 2013, 06:47 PM
#27
Legendary
Just did a self diagnostic test and i flashed out " All circuits that can be confirmed by self-diagnosis are ok" 10 flashes that are the same
2nd January 2013, 06:48 PM
#28
Legendary
Back to the drawing board i guess
2nd January 2013, 06:55 PM
#29
Legendary
Actually i need to go out in a lil bit and will need to do about 40 mins of driving i will try it again then
2nd January 2013, 07:30 PM
#30
Rotaredom
Alitis007
Does this mean you are still getting the error 21. Turbine Sensor still, or just the TC is not locking up............... or both
