23rd December 2012, 01:59 PM
red wire to altinator?
i have been undoing the birds nest of dodgy wiring and found the the red wire to the altinator wasn't even conected to anything. can someone tell me where it come from so i can connect it back up. no wonder i wasn't getting charge.
23rd December 2012 01:59 PM
23rd December 2012, 02:06 PM
There is no factory red wire to the alternator.
Can you follow where it goes to?
23rd December 2012, 02:07 PM
a member of the menagerie
Hey Brett,
Any chance you could put up a pic, I went and had a look at mine but I cannot see a red wire.
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
23rd December 2012, 02:08 PM
it was cut off up near the battery box area. this has the white wire on the post of the altinator and a red wire on it as well.?
23rd December 2012, 02:16 PM
The large white wire is the main charge wire from the alternator to the battery.
If you are getting the 14 volts across the battery.... the alternator is charging.
The red wire might have been put in to run an accessory that may have now been removed.
23rd December 2012, 02:21 PM
ok. cool, i just looked at a wiring diagram and there should only be a white wire. thanks for ya help.
23rd December 2012, 02:25 PM
They may have ran that RED wire straight to the POS of the battery
23rd December 2012, 02:36 PM
threedogs
Hope not, if they did then they bypassed the main fuse.
23rd December 2012, 02:50 PM
i've removed it. still got an altinator problem but at least there isn't a big birds nest under the bonnet.
