Results 1 to 10 of 11
Thread: Tilting fridge slide project
    Oct 2010
    Old Bar, NSW
    This is something I built for the fridge years ago, had it on top of a set of drawers in the back of a ute. When it was tilted it sat on the tailgate, now it hangs in fresh air.
    I have had to cable tie dividers in the fridge basket for obvious reasons....
    It has a couple of large SS door hinges welded to the pivot point and bolted to the bench top.
    I made a spring loaded pin that passes underneath and fits in a keeper bracket to stop it bouncing about also you can slide the fridge straight out, or by operating the pin the fridge will tilt.
    The strut that limits travel has lost its gas so is only to relieve stress on the pivot point stopping it over rotating and damaging the seal on the door frame.
    The tilt has worked fine for 5 years now and can not see it playing up now.
    The fridge is getting a cage made from alum expanded mesh which stops stuff falling under the thing when its tilted.
    Oct 2010
    Old Bar, NSW
    Front on view using standard fridge slide then modifying
    Locking pin in lock position
    Locking pin in unlock position
    Slide down in locked position
    Slide tilted, the keeper for the pin is visible
    Oct 2010
    Old Bar, NSW
    I also fitted a small gas strut to the lid of the fridge to hold the lid open, makes life so much easier
    Macca
  5. The Following 2 Users Say Thank You to macca For This Useful Post:
    AB (23rd November 2010), YNOT (23rd November 2010)
    581 Post(s)
    Cheers for posting how you made the tilt Macca, saw that in your Members Ride photos.
    Perfect for trays and pods!
  7. The Following User Says Thank You to AB For This Useful Post:
    macca (18th February 2012)
  8. #5
    Expert Russell1974's Avatar
    great job mate am lookin at doing something simialar for the back of my wagon
  9. The Following User Says Thank You to Russell1974 For This Useful Post:
  10. #6
    ilikedonuts_10
    Guest
    Does anyone know a good place to get second hand fridge slides to fit an engel 65ltr
  11. #7
    Feb 2012
    wow very nice job mate,,
  12. The Following User Says Thank You to Lahej_sas For This Useful Post:
  13. #8
    Feb 2012
    nice work mate looks tops.
  14. #9
    Hardcore
    central coast nsw
    Looking at building one of these sorta slides, my build will be similar to d&watson tilt slider.
    any idea on strength of struts to use for a 40ltr fridge.
    there's plenty on ebay but strength will be the tricky bit to work out!
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  15. #10
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Jon
  16. The Following User Says Thank You to TheFlyingBadger For This Useful Post:
    the evil twin (12th December 2017)
