5th January 2013, 07:37 PM
#41
Rotaredom
Ok, below are the things you need to test
1-8 you can Test with gearbox in, lucky last number 9 transmission needs to be removed
Do it in order as follows.
1) Throttle Sensor ( Adjustment ): AT32 ( Page 32 )
2) Revolution Sensor and Speed Sensor:
Revolution Sensor Test: AT-69 ( Page 69 )
Speed Sensor: EL-54 ( Page 54 )
3) Inhibitor Switch: AT-68 ( Page 68 )
4) Engine Revolution Sensor: AT-39 ( Page 39 )
5) Fluid Temperature Sensor: AT-69 ( Page 69 )
6) Line Pressure: AT-69 ( Page 69 )
7) Lock Up Solenoid: AT-69 ( Page 69 )
8) Control Valve Assembly
9) Torque Convertor
Not finished yet will let you know when complete
Todd
soulburner2000 (30th March 2013)
5th January 2013 07:37 PM
5th January 2013, 08:23 PM
#42
Everything passes except the lock up solinoid, not engaging, or rather not locking, as you can feel it try then give up...
5th January 2013, 08:26 PM
#43
doesnt the throtal sensor just change if the gears change at lower or higher revs?
5th January 2013, 08:30 PM
#44
Rotaredom
ckh
So you have been through the manual and passed every single one of those 1 - 8 tests???
5th January 2013, 08:33 PM
#45
yes already had a copy of that same at.pdf file that the nissan techs use
yes test x if pass go to b if not bla bla bla
5th January 2013, 08:34 PM
#46
all except I cant find my Throttle Sensor
5th January 2013, 08:37 PM
#47
Rotaredom
ckh
From my understanding, think I seen something in the manual but don't quote me
If you adjust the Throttle Sensor, it changes the the line pressure and incorrect line pressure will cause the lockup not to work
5th January 2013, 08:40 PM
#48
NissanGQ4.2
can you post a pic of what I'm looking for?
5th January 2013, 08:45 PM
#49
Rotaredom
Yours is Carby correct???
5th January 2013, 08:53 PM
#50
Rotaredom
Forgot about this thread:http://www.nissanpatrol.com.au/forum...kick-overdrive
Check post # 13 from me, that the location for EFI, I assume the carby one looks the same and would be located somewhere near the carby.
Maybe send Lucas a PM, just in case he misses this, his is carby and will tell you where it is located.
