18th December 2012, 08:27 PM
#11
Advanced
sure it's not a Toyota engine?
18th December 2012 08:27 PM
18th December 2012, 10:14 PM
#12
Patrol Guru
still sounds like its electrical,could be ur dizzy playig up, put another dizzy in, set it up correctly & try again
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
18th December 2012, 10:16 PM
#13
Patrol Guru
where r u from, someone might live near you
19th December 2012, 05:22 AM
#14
If its gen fuel tank isn't the pump in the tank.
Going up hill, and lose power could mean blocked up fuel filter.
what your describing could be a number of things.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
19th December 2012, 11:27 AM
#15
Hey all i live near maitland. the fuel pumps not pumping now. Its beyond me fixing it ive tryed all i know. if someone wanta to come out and see if they can fix willing to pay them
19th December 2012, 01:52 PM
#16
I would imagine the pump is inside the tank. Sounds very suspect. I'm not sure about on a GQ but there may be an access panel in cargo area to gain access to fuel pump.
Even if you checked fuel at rail, the fuel pump may not be providing enough pressure to the injectors. EFI runs at high pressure.
It's not uncommon for lpg cars to rarely use petrol so therefore the pump doesn't last long when they are eventually switched back to petrol. May also have contaminated fuel in tank.
Try to remove pump and look inside tank. Have a little smell too. Compare the smell to fresh fuel. Goes stale pretty quick. Watch for rust and water and remember fuel explodes, be careful.
Hope that helps somewhat.
19th December 2012, 03:07 PM
#17
Thanks i Assumed it was in tank but im pretty sure ita not there iare no power wires to tank its a belly tank
21st January 2013, 07:10 PM
#18
Legendary
Hi,
I'm a newbee. How do I post a new question/thread?
22nd January 2013, 11:43 AM
#19
In the rear cargo area ,under the carpet or mats is a round plate screwed to the floor, undo that and theres acess to the fuel tank pump,well in standard tanks anyway,but check it out
When the pump gets power it should work,if it doesnt get a new pump ......
You can check the pump, turn the ignition on and youll hear it work,if you cant hear it ,its not getting power or stuffed
You can pull the fuel line of at the rear side of the filter, turn ignition on and check for fuel comin out , no fuel, pump issue
IF you have fuel there, reconnect then remove line forward of filter and go again, if you had fuel pre filter and not post filter, the filter is blocked
IF you have power to the pump, your getting fuel past the filter, then theres something else to check
The checks above wont take 15-20 mins to check
Thats the fuel side ,have you taken a plug out and checked theres spark at the plugs ???
Fuel in , spark happenin ,power where it needs to be it should run
22nd January 2013, 04:34 PM
#20
Patrol Guru
dom14
Hi,
Dom14, go back to where all the threads are & near the top right coener ir says "post a new thread", click on that
