finally used money i wasnt supposed to touch but always knew really that i would.
got a set of my mates second hand alloy 15x10
got booked in for some maxxis 33x12.5x15 M/Ts on monday morning.
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
just checking the 15" arent too tight, the front is only just scraping through. who else runs 15" on a gq with 2" suss lift?
tap some 33x12.5s on it.
yeeeah. there pretty tight in there
got some cosmetic work to do before they go on
GQ came standard from the factory with 15 inch rims you will have no trouble fitting them. Only the offset might be an issue depending in the rims.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
