Results 31 to 37 of 37
Thread: GU - Installing Outback Draw System
  1. #31
    Expert Kast's Avatar
    Nov 2012
    Sydney, NSW
    Guys, installed my OB drawers a few weeks ago. Used existing holes on the front and drilled only at the rear. So four mounts all up. Can't fathom 10 holes as the frame spans between them. Did a trip to karijini, coral bay. Including the buggered and corrugated track to yardie ck. Not a problem at all. I've got a gu iv.
    Sent from my GT-I9305 using Tapatalk 2
    GU IV 2006 Snorkel 225 Driving Lights Dual Batteries Factory Bar Awning Rear Drawers Part NADS (so far)
    Nov 2012
    Sydney, NSW
    I should add I put shims on the spans between the bolted anchor points so they'll stay true.
  4. #33
    Thanks Mate very helpful Cheers
  5. #34
    43 Post(s)
    Ok I'm digging this one up..
    Has anyone with an outback setup fitted the child restraints "aftermarket"?
    My unit has all the holes just not the threaded brackets..
    Have read they charge $30 each bracket... surely not!!
    Surely you could whip one up thats stronger and looks the part.
  7. #36
    Outback's has been through all the testing and is rated
  8. #37
    yeah Gary does very good work, he started off making door pockets for his mates 4x4s
    $30 for a rated bracket priceless
