Results 1 to 4 of 4
Thread: what gearbox is better for p40 engine ,5 speed or 4 ?
    Dec 2012
    do i have to change any thing so i can use the 5 speed transmission ?
    Feb 2011
    Shed
    45 Post(s)
    I believe the tail/prop shaft lengths are different
    A 5 speed will give you better highway driving
    Benarkin QLD
    5 speed has overdrive, thats the only difference,except the SD 33 n/a and SD33 T has a different first gear
    The 5 speed box is around 100 mm odd longer,so longer front shaft and shorter rear
    May 2015
    I'm curious if I can manage an SD33 transmission swap on my 1969 KL60. Can someone tell me if the bell housings of the P and P40 are the same?
