11th December 2012, 04:12 PM
11th December 2012 04:12 PM
11th December 2012, 04:19 PM
Smart like tractor
mine does that but it only hits when right hand down and full compresion.
do you have drop boxes?
do you have radius arm spacers?
96 GQ coil/Cab
08 G6eT
11th December 2012, 04:20 PM
Can you get a photo from the front showing it all sitting in situ?
11th December 2012, 04:37 PM
Yes i have drop boxes and no i dont have radius arm spacers. Mine is hitting like that under normal driving u can also see the coils arnt straight.
11th December 2012, 04:49 PM
Moderator
Can i see a side pic of your Drop Boxes please mate and also a pic of the damage on the back of the drag link where that gouge was done?
Your springs have got a fair bit of bend in them and it seems like the setup is not right. It is like you have fitted radius arm spacers AND Drop Boxes?? As asked above. I note that this is not so but something is amiss.
Check out my Toy -->
Rogue Dung Beetle
11th December 2012, 04:54 PM
Moderator
That damage could only be happening at Full Lock?? Surely?? That must be when you have full lock and the swivel hub is close and the swivel hub / Drag link mount is hitting??? Must be as i cant imagine anything else getting close?? It is certainly not being caused in a straight line as the drag link passes the panard of your steering dampener would be destroyed! its between these two elements.
Do you have the steering lock limiting nuts still in the back of your swivel hubs?
Rogue Dung Beetle
11th December 2012, 04:55 PM
Moderator
where are you located mate?
Rogue Dung Beetle
11th December 2012, 04:57 PM
Moderator
Note also you should turn your steering dampener around as it will fill with water and sand and mud and stuff!!!
Rogue Dung Beetle
11th December 2012, 05:15 PM
MudRunnerTD
MudRunnerTD
What nuts would they be?
MudRunnerTD
Cowra NSW (hr west of bathurst)
MudRunnerTD
Will do
11th December 2012, 05:26 PM
Moderator
Labelled "Lock Nut" in the bottom pic. That is the steering lock limiter.
Rogue Dung Beetle
