I bought a draglink from superior with a GU and GQ tierod ends because I have a GU steering box going into the GQ, One of them has a grease nipple, The other doesn't. I rang superior and the guy said "id say the one with the grease nipple would be GU because of it having a grease nipple, I just want someones opinion on this because I just don't want to buggery it up.
Thanks for having a look, Hopefully this will be all going together tomorrow
The only difference is the angle of the taper. take the rubber boots off and you will see that they are slightly different. you should be able to check you car too and match the taper up.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Local Bulleye guy had pics and size specs in a parts catalogue when I was looking at ends.
What Mudrunner is telling you is on the money they are different in the tapper area and that's all.
