8th December 2012, 08:40 PM
Lifting GQ TI LWB 1991
I'm looking to lift my patrol wagon 4 inches, I've gone with a 2 inch suspension lift and a 2 inch body lift, I'm not sure on what changes have to be made to things like steering, brakes and drive line set ups, any help would be much appreciated
8th December 2012 08:40 PM
5th January 2013, 11:15 PM
For a 2 inch suspension lift you only need springs & suitable shocks.
Do a search re body lift
Where are you loacted?
1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
And its Toooooooo High for the Ball & chain
6th January 2013, 04:55 PM
Mate it is so much easier and better for the vehicle to do a suspension lift then a body lift. Yeah a body lift will be cheaper in the short term but what if your body mounts start cracking you will be up for some major dollars. For a 4 inch suspension lift you are looking at a minimum of caster correction, extended shocks, extended sway bar link pins (I ripped mine from my chassis because i didn't upgrade them), front adjustable drag link, longer diff breathers and break lines. You can easily install the kit on your front driveway with some stands and a floor jack.
TD42 turbo GQ - ironman snorkel - 4 inch flexy coils - 6" shocks - 3" straight exhaust - pyro and boost gauges in A pillar- uhf - winch - sunraisers - Bluetooth - spotties - front lokka
19th February 2013, 03:39 PM
19th February 2013, 05:09 PM
Gee this never got far.....so much for intro!!!
