Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Stopping water getting through snorkel
    581 Post(s)
    I'm getting a lot of water coming through the top of the 4" snorkel if the car is parked downhill in the rain.
    Looking for any ideas on how to stop this?
    I'm happy to go buy a proper pre filter device but not sure on what way to go...
    I don't like these...
    I like the look of the cone pre filter but I don't want to restrict air either?
    I really just need to make something to stop water coming in.
    One idea is to take the rubber elbow at the end off and put on a custom made outer pipe so air sucks from underneath....Not sure of issues with this????
    A simple idea would just to make up a little shelter at the end of the elbow to stop water coming in...
    Id rather just buy something thats properly made to suit a 4" pipe....LMAO....Either coming out on 45 following the A pillar at the end of the stainless pipe or something small to run horizontal after the end of the elbow.
    Any ideas and suggestions?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Dammit Andy, I questioned if rain would get in to that type of set up when I started making mine and was assured that it wouldn't...... BY YOU!!
    An idea I thought of would be to cut the end of the elbow at an angle so it ended up having a veranda. Hard to explain, I'll try to put up a pic soon
    Tap, crackle, pop
    Hello from Under Down Under!
    581 Post(s)
    Ive never had water in it until I parked it on a severe down hill for 10 minutes and now im paranoid...lol
    Something like this would work but not as ugly....smaller little set up more cylindrical would look ok.
    581 Post(s)
    Tap, crackle, pop
    I know exactly what you mean, I was going to build a veranda but cutting the rubber would be easier....
  6. #5
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah I thought to myself, it rains good here and I couldn't see how rain wouldn't get in.
    Tap, crackle, pop
  7. #6
    Aug 2011
    North West Tas
    56 Post(s)
    Maybe that would be enough? It would certainly help
    Tap, crackle, pop
  8. #7
    581 Post(s)
    Good idea mate, my only concern by cutting the rubber on angle would be how close the cut is to the bottom of the rubber.
    If cut close to where the elbow bends then you have a down hill angle straight away asking for water to come down thats all.
    I dont have much horizontal rubber length on the elbow of mine.
  9. #8
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    What if you used a 90 - 130 deg elbow on the end of the pipe so that the opening would be more or less pointing down at the roof? No need to cut anything then.
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  10. #9
    581 Post(s)
    Can you get 130's?.....That would be better too, so the opening is facing downwards more.
  11. #10
    Aug 2011
    North West Tas
    56 Post(s)
    Mine would hit the roof with a 90 or more bend. And the stainless is already cut so I can't lengthen that.
    Tap, crackle, pop
