Results 1 to 5 of 5
Thread: GU II vs GU IV
    Nov 2012
    GU II vs GU IV
    HI,
    I have just joined this great forum. I am "imposter" I guess as I don't own a Nissan yet....but I want to research well before I buy.
    I want a GU Patrol ute about 2006 model. I have been looking at ones for sale and am confused. There, for example is a 2006 GU II DX and a 2006 GU IV DX listed (both with 4.2TD). Is that a mistake or was there a model II and a IV released in the same year? If so what is the difference between the two models? Thanks in advance for help.
    (PS I actually do own a Nissan..I inherited a 1976 G60 on my hobby farm when I bought it. One day I may get it going as a bush basher...lol.
    Geepeem
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    No there was only the GUIV released in 2006. The last of the 4.2Ls were released in 2006. The GUII was 2000ish
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
    Advanced thepunter1's Avatar
    Wheelers Hill, Melbourne
    As far as I know, The UTE only went to GU II, even though it was built until 2006. Check out the grill on a 2006 UTE it is the same as a GU II.
    GU 2006 Cab Chassis
    Don't try to teach a pig to sing it frustrates the pig and wastes your time.
    Nov 2012
    Thanks punter and scotty for your replies.
    The ad definitely referred to model IV and 2006 but as stated this could be in error.
    The only difference in specifications that I could see was in towing capacity.
    The II stated 2500kg while the IV had 3500kg capacity (manual transmission 4.2TD)
    THis is important to me as we will be towing 3000kg van.
    Regardless of the model name....do you know what year the Patrol Ute was rated at 3500kg tow capacity?
    Thanks for your responses.
    Geepeem
    Checkout Redbook for the details.
    The Patrol GU II Ute basically come in two variants;
    The Leaf version (coils front & leaf rear)
    Leaf
    Towing Braked (kg) 2500
    and the Coil
    Coil
    So from what I can gather the GU II Utes were both 2500 kg. The 2006 Wagon however does appear to be rated at 3500 kg.
    GU 2006 Cab Chassis
