7th May 2012, 11:19 PM
#41
7th May 2012 11:19 PM
8th June 2012, 06:10 PM
#42
Thought I'd throw in my 2 cents guys. Found these guys on the web, they are in South Oz, they have a bit of a selection of catch cans, not ridiculously expensive either if you don't want to make your own.
http://www.dtsturbo.com.au/3350_dash...Plastic/pd.php
18th June 2012, 09:30 PM
#43
I installed a Tiapan catch can, yet to see what happens
31st July 2012, 10:34 PM
#44
What about running the hose say down the back of the block into the chassis rail and making sure there is a good one way valve near the tappet cover so it doesn't suck a gut full of water if you stall it in a river or something? Yes it's technically illegal, but my road reg dirt bike is like that from the factory and it's been through many times deeper water/mud than I would ever take my patrol... It will also rust proof the left hand chassis rail too!
1st August 2012, 12:19 AM
#45
robbo0001 id watch that level indicator hose on that catch can, a mate had on his car and it went cloudy hard and then cracked don’t think he had it on long either but it might have been due to the heat under the hood as he uses his car for drifting but all the same just keep an eye on it or pull it off and whack some bolts in place of the fittings it’s not going to fill up between services anyway so an indicator isn’t really necessary
1st August 2012, 06:29 AM
#46
Hey Mega,
sorry mate, I must have posted in another thread.
I uninstalled this about 2 months ago, now have a bolt in the intake pipe to seal it, and have run the PCV line down the wheel well and attached to the chassis rail.
Definately no oil in intercooler from the pcv now.....just have fingers crossed no seals in turbo are leaking, am yet to check the intercooler again.
cheers
Dave
99 GU 2.8 TD
Brisvegas, QLD
2nd September 2012, 09:43 PM
#47
Hey all. as someone that is not slightly mechanically minded is this a catch can that has been put it. and how would i drain it there dont seem to be any points to do so
18th November 2012, 01:12 AM
#48
robbo0001
50,000km....or ten years of average driving?
How can that be possible?....it's a filter, and a non re-useable/ washable one, as well.
I thought avg K's were 20 000 per yr.
big diff , no offence
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
18th November 2012, 01:15 AM
#49
White Elephant
looks like a in line water filter .
5th December 2012, 02:56 AM
#50
I put one of the super cheep auto one in my 3lt but was told to use the green scour pads they don't break down as much as steal wool
