23rd November 2012, 05:08 PM
Cold side of brake switch
I have a GU IV (STS). I'm about to install a tekonsha P3. It tells me to connect wire to cold side of brake switch.
I've looked inter dash and there appears to be two switches. One has button operating off brake pedal. There are two wires going to this switch. I don't own a meter, can someone tell me where I connect wire. I'm right with all other location but not cold side of brake switch. HELP
'shakey'
23rd November 2012 05:08 PM
23rd November 2012, 05:21 PM
Moderator
I read a post along the same lines only last week mate, have a bit of a look around the Electrical section, it wont be too far away. I believe the second wire is for the ABS maybe?? Maybe if you drop out your rear tail light and see the colour of the wire going to the rear globe and try and match that at the pedal. should be the same.???
Otherwise Yendor will be about later i am sure.
Check out my Toy -->
Rogue Dung Beetle
23rd November 2012, 05:22 PM
It should be the Green with a Yellow trace wire.
MudRunnerTD (23rd November 2012)
23rd November 2012, 05:23 PM
Moderator
Have a read of this thread for the answer maybe?
Brake-light-switch
Rogue Dung Beetle
24th November 2012, 06:07 PM
Thanks everyone. I think I have it
'shakey'
