Results 1 to 8 of 8
Thread: oem pcv valve
    Expert stevogq's Avatar
    behind you
    oem pcv valve
    so i went into nissan to get a new pcv the bloke quoted $295- for a new one!! damn expensive for something so simple and when i asked why so expensive his reply was its quality nissan :/
    Then he told me to just block it off and when i questioned him to why the crank case dont need to breath he told me its for epa reasons thay use it and its a really big fine if they bust you, I told him he must be mixed up from the egr valve.
    can someone point me to another way of getting around this or do i need to folk out 295 for a new one?
    Why does it need replacing? You should be able to just give it a clean out and keep travelling.
    behind you
    I'll give it a try
    You will have to remove the rocker cover to do so but isn't a very big job. Is it blocked?
    behind you
    It's not but I'm getting a fairbit of blowby
    Aug 2010
    adelaide
    id be giving garry at nissbits a call
    also for your info did some hunting around anfound this site for parts no
    http://www.motospecs.com.au/assets/f...m_Switches.pdf
    the info is and its an australian site
    Patrol G60 1/61-12/80 6 4.0L P40 PCV-005 Not Used
    Patrol GQ 2/88-12/95 6 3.0L RB30 PCV-102 Not Used
    Patrol GQ, GU 1/90-9/01 6 4.2,4.5L TB42S,TB45E PCV-100
    so went to another site and found prices
    http://www.eziautoparts.com.au/index...valve&x=10&y=8
    under $20.00 i think id give the nissandealer a big miss MHO
    OH LEATHER IS NICE
    behind you
    Quote Originally Posted by my third 256 View Post
    Thanks for that great info but ive got a rd28, I can't find one for it its a round valve that sits onto of the engine around 75mm in diameter, Nissan calls it a air control valve
    Aug 2010
    adelaide
    put a picture up so i know what to look for please
    OH LEATHER IS NICE
