17th November 2012, 11:16 PM
Mitsubishi TD05 Turbo identification
G'day Trendsetters,
Found the following info below regarding Mitsubishi TD05 Turbo identification from the US. I thought you folks might be interested!
Regards,
RLI
How to Identify the Mitsubishi Turbo Serial Number
By Garrett Genet, e-How Contributor
Identifying the serial number of your Mitsubishi turbo TD05 is straightforward; you need to carefully examine the engine under your hood. The serial number is clearly printed on the compressor itself, or a metal tablet welded onto the compressor. It's clearly labelled and easily identified. A serial number uniquely identifies your genuine Mitsubishi TD05 turbo, so should you ever need to replace it or have any work done otherwise, it becomes a reference you can effectively use.
Instructions
1
Find the model and part numbers cast onto the compressor cover. The compressor cover is the main housing, which resembles a hair dryer. The compressor wheel is located in the centre of the compressor housing. On each side of the compressor housing, surrounding the wheel, are the model code and part numbers.
2
Identify the compressor housing model number. On genuine Mitsubishi TD05 16G turbochargers, "TD05" is cast onto the compressor housing in raised print. The compressor model number normally contains further designation, such as "TD05H," which is also a wheel designation, however, the "TD05" designation is required of all genuine MHI TD05 16G turbochargers.
3
Locate the MHI TD05 16G compressor housing part number. On the compressor housing, opposite the model number, is a ten-digit part number. All genuine MHI TD05 16G turbochargers begin with the prefix "49178," followed by the two digits, "01." These positions are cast in raised digits, while the remaining three positions, or suffix, is hand stamped onto the compressor housing. The suffix determines the specific 16G model.
4
Determine the MHI 16G turbocharger model. The hand-stamped suffix for the different MHI 16G models are the following: "420" and "412" identify the big 16G turbo, "450" identifies the EVO I big 16G, "460" for the EVO II big 16G, "470," identifies the EVO III 16G, while "520" identifies the small 16G.
The halls been rented the bands been paid, time to see you dance!
The Following User Says Thank You to PMC For This Useful Post:
MudRunnerTD (11th July 2013)
17th November 2012 11:16 PM
17th November 2012, 11:25 PM
This adds to my curiosity about the turbo I have purchased. I am happy with how it performs so am ok with what I have paid for it and whats done is done. I wasnt able to find any info regarding MHI and anything larger than a 16g. Looking at the turbo I have its exactly as what you have been described by old mate in NZ the only difference being is the turbine hoising has been machined out. I am still yet to see anything about the cheaper jobs failing.
11th July 2013, 02:54 PM
G'day lounge lizards!
I am really curious if folks are getting value for money from turbo's that they purchase. Like all branding at present, are you actually getting a better product for your dollar? Are they there similar products being sold cheaper from the same turbo manufacture? Buyer beware i say at present.
PS, stay tuned, I will report further about this matter soon!
Regards,
RLI
11th July 2013, 06:37 PM
Bump!
Regards all forum members! lol
RLI
11th July 2013, 07:01 PM
Smart like tractor
RLI
Regards,
RLI
I will be able to update soon I am heading to brissy to pick my new GTX3071r from MTQ. I have ordered a wastegate and a different turbine housing from the states which should be here monday only ordered it at the start of the week too. Which brings me to my next point. I ordered a turbo from ufi in march and was told a week. They wouldn' t return calls and mid june i get a call saying they were about to start. So I said dont bother and went for a garrett instead.
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
11th July 2013, 07:10 PM
Ben-e-boy
Which will net us some awesome results
The Following User Says Thank You to nissannewby For This Useful Post:
14th July 2013, 08:00 PM
nissannewby
G'evening mate,
Question: where can i source a dump pipe to fit my new turbo?
Regards,
RLI
22nd July 2013, 09:52 AM
Matt I can tell you that, the turbine housing on your turbo is made for the supplier of your turbo and cannot be brought elsewhere.
And there are other internal differences between say your turbo and a Kinugawa version of the same thing. A bit like my turbo, allthough it is a garrett GT2871 it is not like any other 2871.
As for one thing looking like the other, yes that is most likely the case. Closer inspection though may reveal weight differences between internal components and slight profile differences. Materials may also be slightly different. While SUPPLIED by OEM manufactures this does not mean they are the same as OEM equipment.
Ben, will be interesting to see how the GTX3071 goes. I am not a fan of the full blade style compressor wheels, and especially the one you have chosen with its larger compressor wheel trim. The larger trim just hurts response, and along with the reduced efficiency of the of the lower blade count of the GTX type wheel in the lower boost region I have not seen any results for them that impress me. I do have a full blade style GTX compressor wheel here in 56 trim, it will just end up a paper weight. Smaller inducer sizes with a more open inducer like with conventional type split height compressor blades with a higher total blade count are much better suited to our application in my view.
I have had a compressor wheel built for my next turbo which is different again, we will see how it performs. But all with the idea to get everything happening a little sooner which the GTX compressor wheels don't do well.
Marty
The Following User Says Thank You to Bambill For This Useful Post:
22nd July 2013, 11:41 AM
Bambill
Marty
The comment you referred to was made a while ago. I have since found on my quest for knowledge more about the turbos and their modifications. I even emailed MHI direct. The turbo I have works really well and I don't have any dramas with it, its a good product. Hopefully I have worded this correctly this time aye.
26th July 2013, 12:30 PM
Ben-e-boy
G'day Ben-e-boy,
Sorry to hear about your bad experience with UFI!
PS, i will be heading down the Garrett path myself next, after speaking with OldMav on the Patrol4x4 forum i am looking for another challenge!
Regards,
RLI
