Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Radio advice
  1. #21
    I've got a Uniden one in mine, dunno the part number but it has a remote mic on it which is awesome. Does need an external speaker though I reckon as it's not loud enough.... is it possible to play the sound through your car speakers?
    Mar 2013
    Mackay, QLD
    Quote Originally Posted by NP99 View Post
    Plus GME is Aus made from memory.
    Correct. Manufactured in Sydney; so as well as supporting the Australian economy Service and Support is never far away.
  4. #23
    Patrol Guru
    Apr 2011
    Melton
    We have used gme a few times to fix faulty GME radiov - cost was resonable.
    I use a RFI MOPLE Groud indepandant antenna mounted on my bull bar. see http://www.rfiwireless.com.au/mobile...l#.UVGPNRdTDTo
    They have a gain of 4 db, and due to being flexable can handle a branch or bird strike.
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  5. #24
    ive always used gme radios in my car and uniden hand helds, am thinking about moving over to ICOM as ive heard good things
  6. #25
    Mar 2013
    Mackay, QLD
    Icom's are a great radio. They are commercial and Mil Spec radios. Extremely hard wearing and really difficult to break. The GME's are a great radio, but they are made to consumer specifications. The circuit boards in them are probably just as good, but they don't have the heat sinks on the back to help them cool (not that a CB should generate too much heat at 5 Watts anyway) or the heavy duty cases or faces. GME's are just thin steel cases with leightweight plastic heads. As I said, nothing wrong with them and they work great in most equipment (even plant equipment), but the cases aren't made to the same standards as Icom.
    Regards,
    Brian.
  7. #26
    Patrol Guru
    Apr 2011
    Melton
    We prefer the Icoms at work - but also have GME's
    Note I suspect the ealier Icom440 cannot be upgraded to 80ch's
    The gme that was rated at 25 watts, would have its poer set at 5 watts for the UHF band
