Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Westy's Ride
  1. #21
    Expert Brendan56's Avatar
    Townsville
    Not a problem. Gotta make sure you have the best stickers around ;-)
    Tappin trolls
    Brendan
    If you're following this Patrol, Stop... You're not gonna make it
    Looks sweet as brew
    Don't slap it, tap it!!!!
  4. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (8th May 2013)
  5. #23
    43 Post(s)
    Cheers boys. Yea Lucas is the man for anything vinal.. Anything...
    Owner of
    Westy's Accessories
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Brendan56 (7th May 2013)
  7. #24
    Apr 2013
    Victor Harbor SA
    Hey Westy, GQ is coming along nicely mate, I have 89 GQ with a few upgrades planned, just curious if there was anything specific you did to paint your rims? I still have white sunnies and was also going to paint them black ?? Cheers
  8. #25
    43 Post(s)
    Thanks mate. A bit to go yet..
    Well bud first time was a rush job..
    Lasted about 12 months..
    So second time around ill be removing the tyres, pulling the valves.
    Getting sand blasted and primed, then a 2 Pac top coat.
    I'm also going to run balance beads, read good things about them. So no weights to chip the paint. I guess you could run the stick on weights, but the have been known to come off in the mud..
    Owner of
    Westy's Accessories
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    SamGQ89 (29th May 2013)
  10. #26
    Apr 2013
    Victor Harbor SA
    Thanks mate, yes thought I might just give it a quick go, looking to get some new rims and tyres in about 12 mths anyway!
  11. #27
    80 Post(s)
    It looks great with all the work you've done on it, since I saw it , Kallen. With all the goodies on board, is an alarm and or a tracker in the to do list?
  12. #28
    43 Post(s)
    No not yet.. might be after its back on the road..
    Will be off sometime next month to start the tear down.. will have to subject myself to a toyo.. so will be pooring every spare second into it..
    Owner of
    Westy's Accessories
    43 Post(s)
    Ok, update time...
    Its taken a while but I think I've done a bit..
    Diff has had seals and bearings done, and laminated.
    New panhard bushes
    New drag link and tie rod ends
    New hoses and belts
    New extended brake lines and a full flush and 're-bleed.
    New thermostat, gaskets, and fan
    Engine service
    Stripped interior
    Still to do
    New radiator
    Clutch master and slave cylinder kit
    Repair cracks in body
    Sound deaden the interior
    Clean or replace carpets
    Roof console
    Drinks holder
    Water tank with pump
    Long range fuel tank
    Adjust tappets
    Stainless snorkel
    Turbo...
    And after today and approval from minister of W&F 33" tyres..
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Frontbumfab (8th October 2013)
  15. #30
    43 Post(s)
    Update
    Interior has been stripped out
    Cracks have been welded up
    Every open crevices has been sealed,
    Sound dampening done..
    Front suspension finished and boy does it drive nice. No dampener, no wheel balance and no wobbles at 60 anymore.
    So far so good..
    Still to do..
    Finish interior,
    Enjoy it
    Receive and fit LR tank
    Adjust valve gaps
    Radiator
    Snorkle
    Wheels
    Injectors
    :banghead:
    All before Simpson crossing..
  16. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Parksy (3rd December 2013), Stropp (2nd December 2013)
