Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: My little compressor went.. Well nothing
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by Yendor View Post
    It will work well until the smoke comes out.
    Yes I have realized this. But has anyone had it happen, or just the temp sensor cut out??
    Owner of
    Westy's Accessories
    Legendary happygu's Avatar
    2 Post(s)
    The Temp Sensor is designed to shut the compressor down if it is worked too hard. The motor windings will get hot, and if they get too hot, the windings could melt or the unit itself catch fire.
    I wouldn't disconnect it permanently, but as a temporary solution to get you out of a hole just disconnect it by cutting and joining the wires ( in effect you are just cutting another switch out of the circuit )
  4. #13
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Update.. Well I went digging.. The temp sensor was nowhere near anything.. It was stuck under the mounting plate for the brushes... A good 10mm from anything..
    After cutting everything off it turns out the solenoid was stuffed.. Well now it's a direct motor to battery with 30A fuse in it.. Kiss...
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by macca View Post
    Could also be the solonoid coil is open circuit and wont pull the motor contacts in so motor no go as you have found.
    MMMMmmmmm did mention that one LOL
    Least you have it working now, KISS is good
    Macca
  6. #15
    Some compressors don't like it under the bonnet, just the radiant heat from engine will stop them working. recess them into rear 1/4 panel or mount under a seat somewhere. Can always run breather like a snorkle to get clean air not Elephant science. if thats a science, .recess it in rear 1/4 panel .had mine in rear small door on other 4x4 with spring loaded door. just make sure wires are adequate
  7. #16
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Yea that's what happened to my first compressor under the bonnet.. It lasted a week.. I got it under warranty because it disentangle state not to mount under bonnet..
    But I was going to build this one into my draw system..
