Results 11 to 20 of 24
Thread: Which Mount for an IPad2 ?
    brisbane
    all parts size b
    base x2 (RAM-B-202)
    long double clamp (RAM-B-201-C)
    ipad holder (RAM-HOL-TAB3U) can hold ipads with rubber cases and even flip cover cases
    i think all up it was like $80 the ball is discreet where it is mounted so when not in use its not visible
    and the pad isnt obstructing my view.
  2. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    MudRunnerTD (22nd May 2013), skiman (24th May 2015)
    Expert billy bleed's Avatar
    Mar 2013
    Ram mounts ++++++++
    Black Irish with an English twist / Gypsy / Tattoo's and loaded full of Grumpiness.. I blog my paintings and other random bits on Billy Bleed
  5. #13
    330 Post(s)
    Mega I like that ALOT!!
    Did you take the box out to bolt an nut it in or are they just self tapping screws into the plastic??
    That's great! I was going to use Velcro into the pen ledge and a dot behind onto the days to old the iPad in position in that slot but I like what you have done! You have no trouble changing gears and stuff?
  6. #14
    Ballarat, Vic
    174 Post(s)
    Yes I like it a lot too. Despite the Patrol being a large vehicle, space inside the front cab is pretty limited & difficult to find a spot for the ipad that doesn't get in the way or lend itself to a 'cluttered' feel.
    Unfortunately for me the dash in my DX is different, I don't have that space between the two air vents, instead the two air vents take up the entire width.
    What model Patrol is yours Mega? Maybe I could find one at a wreckers & do a switcheroo?
    In the meantime my wife continues to hold the ipad which is mostly a better solution than many on the market.
    Cuppa
    A Nomadic Life (Blog)
  7. #15
    330 Post(s)
    Cuppa
    Hey Cuppa you have a GUIII dash. Mega is a GUIV and completely different. Sorry mate
  8. #16
    Patrol God Stropp's Avatar
    31 Post(s)
    I bought the same one as mego and it works a treat, still moves a bit but i fixed that by having the weight of everything on the wing nut inside the compartment so its got a solid base to rest on, works a treat.
  9. #17
    Ballarat, Vic
    174 Post(s)
    Bugger! I guess I'll stick with my wife then, though I hardly dare refer to her as my ram mount.
    At least it confirms that I have a GU III.
    Cuppa
  10. #18
    brave man indeed Cuppa, brave man indeed , please confirm later that Mrs tea has read this.
    with the Dx ute being "different", is it poss to make a small shelf across the top of windscreen
    and make something that "flips down"
    @ Mega what model is yours as that dash is different again series 4 ???
  11. #19
    330 Post(s)
    Its a Series 4 and later 3D, he has fitted an after market Stereo.
    Mine is identical to his. the glove box at the top that Mega has used is where they fit eh Factory GPS in the TI models Us plebs get the glove box.
  12. #20
    Ballarat, Vic
    174 Post(s)
    ... the glove box at the top that Mega has used is where they fit eh Factory GPS in the TI models Us plebs get the glove box.
    Ha, that'd have to pee off the Ti owners who want somewhere to mount an iPad.
