Results 1 to 9 of 9
Thread: GU UHF Install
    Nov 2012
    Bayswater North, Vic
    GU UHF Install
    Hi All, i know this has probably been as a lot, i am new to this site, i have a 2000 patrol st zd30. i am looking to put my uhf in to it, where is the best place to run my coax cable and and place my uhf unit i have a icom 400 pro and because i have a pioneer double din head unit i cant mount it there so i am looking for other places to mount it. if you have any pics please post them up.
    cheers chris
    Expert CorbinsGUte's Avatar
    Townsville QLD
    Hey mate when i put mine in my ute i ran the cable through the firewall on the left. Found some good holes to stick it through up under the glove box. Hope this helps
    Sent from my GT-I9100 using Tapatalk 2
    Got the same set up main unit is under the dash on the drivers side.
    Coax out under the LHS as well
    Nov 2012
    thanks for the replies, threedogs what mic is that?
    .......... TPC's Avatar
    63 Post(s)
    Threedogs, looks like yours is a Icom 440 not 400 Pro, the 400 Pro has controls on front of radio.
    63 Post(s)
    Where are you planning on putting the aerial, gutter or bullbar?
    Nov 2012
    I have my aerial mounted on the bar lhs
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    If your Patrol Doesnt have ABS then you should find it easy to go through the Large Rubber Grommet on Passenger side of firewall and from there you can run it under the lip of the carpet to the center. What about mounting the UHF on the side of the center console near the gear leavers on the Passenger side? Next to the 4wd Leaver? Then can Get power and earth from back or Cigarette Lighter socket and hide all the wires under the center?
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  10. #9
    Nov 2012
    Thanks for the replies, Fletcha I do have abs but I managed to get the coax through that grommet and I already mounted my uhf in the location you thought of
    Cheers chris
