Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: 2" Flexy Coils to get more articulation
  1. #21
    The Forest
    Sorry NisHead its taken me a while to reply here.
    Have a chat with Shane at Suspension Stuff in Brizzy.
    I have never had any problems with the coils dropping out.
    Phil
    2010 GU7 Patrol ZD30 Manual - 33"KM2s - 2"lift - ARB front locker
  2. The Following User Says Thank You to create For This Useful Post:
    Maxhead (1st November 2012)
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    What length shock are you running?
    Owner of
    Westy's Accessories
    The Forest
    2 inch lift but using variable rate coils. I think they are King branded
    The shocks are OME brand and are 4 inches longer.
    I bought it as a matched set from Suspension Stuff
  6. The Following User Says Thank You to create For This Useful Post:
  7. #24
    22 Post(s)
    hey chris
    you could take the shock out and flex it up until the coil is about to drop out (if you dont want retainers or drop out cones) or untill you are happy with the amount of droop. Then measure between the shock mounts and size the new shock accordingly
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  9. #25
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    hey chris
    Great idea.. It would be interesting to see how long a spring is unloaded compared to loaded..
    Owner of
    Westy's Accessories
    22 Post(s)
    Owner of
    Westy's Accessories
    there is a bit of difference in length. in the rear of mine I dislocate the spring about 70mm ish (4 inch flexy coil) and I have a fair bit of down travel
    96 GQ coil/Cab
    08 G6eT
