Results 11 to 20 of 26
Thread: 2" Flexy Coils to get more articulation
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Once I win the 70 milion jackpot tonight I will let you know how I got to the moon with my flex....hahha
    ________________________
    ______ 2017 D-Max _______
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Well I'm not sure if you saw my post, but this is a stock 2" OME setup with the factory rear disconnect, disconnected..
    http://www.nissanpatrol.com.au/forum...ad.php?t=15434
    Owner of
    Westy's Accessories
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Maxhead (30th October 2012)
  5. #13
    I hear your dilemma, it's hard to sort of have the perfect set up, as in a capable tourer and off road billy goat.
    These flexi coils sound like they are the answer. hope you get your fix very interesting thread
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #14
    ACT
    Thank you guys, great feedback and advice .
    Once I decide what I'm after after weighing up pros and cons I will sort something out. Being an amateur when it comes to this kind of stuff makes it interesting but exiting all the same
    It will be tough to get an all rounder i reckon
  8. #15
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    maate i drove around for 2 years with the front sway bar still bolted to the radius arms but disconnected from the mounts as i needed longer connector rods when i fitted the drop boxes. I have now unbolted it and will never refit it. Simply Not needed!.
    So with the front disconnected how's the body roll on the highway?
    I'm curious as mine is a daily driver
    Owner of
    Westy's Accessories
    brisbane
    Ive seen superior have superflex radius arms in a standard length, you just buy one not a pair, so you use one genuine and one s\flex arm would suit a 2 " lift. Think they were 650$
    They also have front shock tower mount extensions to allow for longer shocks but involves a bit of wheel arch mods to fit
    Any one tried any of these ? On a 2 " lift ?
  10. #17
    330 Post(s)
    Un-noticable. i honestly thought i would have to buy the sway bar extensions but didn't know what length so thought i would fit the drop boxes and then take a measurement. As stated, i have now removed the front completely. I am so impressed with the ride-ability that i am seriously thinking of re-fitting the rear sway bar to the GQ and removing the front disconnects and sway bar off the GQ as that thing has far far worse Body roll!
    My GUIV is a Pleasure to drive and i have Never felt a noticeable body roll in this car. This current setup is about 50,000kms old now.
    Quote Originally Posted by megatexture View Post
    I have 50mm shock tower extensions on my GQ running a 5 inch lift and had no trouble fitting the extensions. Plenty of room.
  11. #18
    brisbane
    Have to do a little wheel arch chopping to get the extensions fitted and access to the top of the shock on a gu well the ones ive looked at anyway
  12. #19
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    I think you can fit 1" shock tower extensions without a body lift, but it makes it a little harder to get the top bolt..
    And my front sway bar is coming out this weekend.. I'll see how it goes?
    Owner of
    Westy's Accessories
    Nov 2011
    Brisvegas Northside
    I have 2" Suspension Stuff lift, monotube shocks and HD rear springs. Have removed front swaybar, don't notice anything on the road. Awesome travel offroad, the kit came with extended brakeline, brake bias bracket, paid extra for bigger bumpstops.
    Awesomekit....I wouldhighly recommend it
    Dave
    99 GU 2.8 TD
    Brisvegas, QLD
