10th November 2010, 07:21 PM
Thermo fan on top of my intercooler
Hi Members,
Can anyone post pics on what size fan and how to instal a thermo fan on top of a intercooler
Nissan Patrol GU4 3.0ltr 2005
10th November 2010 07:21 PM
10th November 2010, 09:41 PM
I'll have to go hunting to find the pics you're after, but in the mean time check this link to ARE's website. It's a big page with LOADS of info on Patrol intercoolers with facts and figures to back up everything they say. Towards the bottom is a few paragraphs about the effects of fitting fans to intercoolers.
http://www.are.com.au/Inter/topMountIntercoolers.htm
Tony
The Following 2 Users Say Thank You to YNOT For This Useful Post:
AB (10th November 2010), NissanGQ4.2 (10th November 2010)
10th November 2010, 10:23 PM
11th November 2010, 08:47 PM
Tony,
Many thanks for your expertise in all Patrol matters
13th November 2010, 11:23 AM
Hi
Can any tell me if this mod works pls?
13th November 2010, 11:27 AM
Short answer is the fans are beneficial at low speeds but cause an airflow restriction at high speeds.
Check the link to ARE intercoolers in the second post, these guys have done a ton of research into the subject.
Tony
1st December 2010, 08:16 PM
hey tony is the bigger intercooler a better option over the fan????
1st December 2010, 08:33 PM
In my opinion yes. But to get the most benefit from the bigger intercooler you need a bigger/taller scoop.
Tony
8th January 2011, 10:22 PM
justrocho
Since most of the pics in this thread are mine I thaught I would answer your question.
The larger intercooler makes a big difference over the standard one. EGT are roughly 100c less with the Cross Country intercooler. The fan on the Cross Country intercooler is mounted underneath and works very well.
Adding a fan to the factory intercooler makes a noticable difference but it is not the same as a larger intercooler.
Please note that the intercooler in the first pic is not mine (Its Patrol King's). I dont like that method of mounting the fan because you get a lot of air passing around the intercooler instead of through it.
Mount the fan on the engine cover so the shroud still works.
18th February 2012, 07:53 AM
thanks for the information i am having a problem and this thread helped
