19th October 2012, 05:14 PM
04 sounds like blow off valve
Hi all not overly concerned but lately I've Been able to hear the turbo a bit louder. at first thought noise was coming through the radio. Read another member had a similar problem and they said leaking intercooler. Now I get a sound like I have a blow off valve fitted, and constant cold/hot its the same. Gee I hate these computer cars. any ideas would help
19th October 2012 05:14 PM
19th October 2012, 05:41 PM
It does sound like a boost leak. Also check your intake into the turbo make sure it hasn't been dislodged.
The Following User Says Thank You to nissannewby For This Useful Post:
threedogs (19th October 2012)
19th October 2012, 05:45 PM
Thanks mate I'll take the cover off tomorrow and check everything, boost is set to 14psi and it goes great.
just that very annoying sound,
19th October 2012, 05:55 PM
Also have a look around the EGR valve and pipe for leaks.
If you have a major boost leak you should be able to pick this up by your boost gauge.
The Following User Says Thank You to Yendor For This Useful Post:
19th October 2012, 05:59 PM
Boost seems normal but after I remove the cover I'll run a spanner over everything thanks mate. everything mentioned is all I have touched with NADS etc
20th October 2012, 02:43 PM
Rightio, removed engine cover, looked normal. checked hoses all were ok, checked egr {blocked} all tight.
other than trying a bigger hammer I'm at a loss.
One thing I did notice was at 2000rpm normally I have 10LB psi. now its 5LB psi. losing pressure as suggested.
so taking it the IC is knackered as everything else looks ok. Thoughts please,
gee I hate these things.
The Following User Says Thank You to threedogs For This Useful Post:
Cuppa (28th October 2012)
20th October 2012, 04:00 PM
That drop seems very high to be caused by a leaking IC.
Did you check that all the hoses are still on the flanges correctly?
threedogs (20th October 2012)
20th October 2012, 04:29 PM
Yeah They look good other than R and R I just nipped clamps, will check again Thanks Yendor
Split hose maybe but appear in good nick.?
20th October 2012, 04:39 PM
Possible, My IC was leaking for over 2 years before I replaced it and it and I never had a drop in boost like that.
It would have to be a fare size hole.
When a hose on mine partly dislodged on the IC flange, boost was about halved.
You may also need to start looking at the turbo.
20th October 2012, 04:45 PM
Don't say that as I'll sell it. Got no $$$$ for a turbo fix
