Results 1 to 10 of 19
Thread: Fixing GQ Roof Rust
Threaded View
    Beginner Devious 4x4's Avatar
    Fixing GQ Roof Rust
    Gday, Just thought Id show my latest project on the Patrol.
    When I bought it a few years ago there was rust in the roof above the gutter on the drivers side above the rear window.
    I ground the paint back and found it was just surface rust with no holes through the metal. So I rust treated it and primed it and that was it, I never painted it, which was a bad move as the rust came back and much worse!
    So I ground it back again and found there were a heap of holes in the metal.
    So I figured I might as well cut the rust out and fix it properly. So I cut out the rusty areas and found the inner frame of the roof also had surface rust and lots of moisture in there, and the small hole I cut also had a heap of rusty metal flakes behind it.
    So I cleaned the inner frame up with a wire wheel on the die grinder, rust treated the areas and coated them in a Kill Rust epoxy paint to prevent more rust from forming.
    I then cut out replacement sections from some steel I had, which I had zinc coated on the inside to prevent future rust and welded them in. I also removed the rear side windows, so I could lower the headlining to the back seat, which would allow me to keep an eye on any potential fire risks. I also had an extinguisher handy just incase!
    After I cleaned up the metal it only needed a little filler to smoothen everything up and it got a coat of 2K high fill primer.
    I have to let the primer cure for 24 hours, So it will get a coat of paint during the week. The job took me about 7 hours in total, and that was just taking my time. A decent mig welder would make it quicker, but ive only got a gasless mig, so there was lots of cleaning up welds involved!
    Thanks for looking!
  2. The Following 5 Users Say Thank You to Devious 4x4 For This Useful Post:
    bomberNZ (2nd November 2016), Family4x4 (16th September 2014), jasonwoodland (2nd January 2018), NissanGQ4.2 (14th October 2012), oncedisturbed (16th September 2014)
