10th October 2012, 05:24 PM
#11
Yeah white smoke is unburnt diesel. It sounds like it may be timing related you will need specific tools to set it and is probably best left to a specialist. With the right tools the job is quick an easy and shouldnt cost to much getting someone to do it.
10th October 2012 05:24 PM
10th October 2012, 05:34 PM
#12
thanks. going to ring around tomorrow and get it looked at.
Can also be related to low compression I hear, but hopfully everything else is ok. head gasket was replaced with the same 3 notch one, so that should be at least right
10th October 2012, 05:44 PM
#13
Yeah it can be compression related too. Get a compression test to I find it strange for compression since its just had a rebuild.
10th October 2012, 07:56 PM
#14
Hardcore
Give it a while to let the new rings bed in.
When you fitted the rings, are you sure they are up the right way.?
After honing the bores, did you wash them with soapy water.?
Is the inlet manifold nice and clean?
So much for brand new Ebay injectors lol.
Parts like injectors need to be the best quality, not some busted arz Chinese import.
Cheers, the ferret
10th October 2012, 11:32 PM
#15
ah ok, yeah took it for a drive and it is less smokey now. might just be the 2nd hand injectors running in after sitting idle so long (from a wreck)
can it blow white smoke while the rings are bedding in?
yep all parts installed correctly and bores washed etc. manifold had a very good clean.
learnt my lesson with those ebay reco injectors *sigh* what a waste of money
10th October 2012, 11:44 PM
#16
Hardcore
White smoke is cold engine and /or low compression/ poor ignition, once the rings have settled it should improve.
If your valves are too tight, it will smoke as well.
Just drive it normally and don't idle it while the rings are bedding in.
Should clear up after 1000 ks.
Cheers, the ferret.
The Following User Says Thank You to the ferret For This Useful Post:
Dr.Zoidberg (11th October 2012)
11th October 2012, 07:55 AM
#17
thanks. time to put some k's on it
11th October 2012, 03:42 PM
#18
Hi mate.
When I rebuilt my engine I also fitted new nozzles. But when I checked them on pressure stand each of 6 had a wrong open moment pressure and needed to have some regulations.
Also when I fit all new parts I refit the injection moment because I changed it a year ago and with normal pressure in cylinders I had white smoke too. So maybe you should recheck your nozzles for pressure test and check the injection moment, may be previous owner also changed it.
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
